I am solving the following problem (solvability condition satisfied)
"a(u,v)- lam* b(u,v) = L(v),
where lam (non-zero) is the eigenvalue and the non-trivial null space is spanned by gfu, i.e. a(gfu,v) = lam* b(gfu,v)."
I assume that one cannot simply assemble the bilinear form "a(u,v)- lam* b(u,v) ", since lam is an eigenvalue. Is there a way to solve this PDE in netgen?
Could this be realized through defining a FE space incorporating that the solution u is orthogonal to gfu? If yes, does netgen provides such modifications?
I don’t think you can do this purely in NGSolve without some C++ hacking, but if efficiency is not the key point you can use NGSolve to assemble the matrices, then convert them to scipy matrices and do the orthogonalization and solving in scipy…
I think we need more information for this problem.
Have you computed the Eigenvalue/Eigenvector in advance, or should it be part of the same equation ?
Are your matrices symmetric and positive definite ?
If you know the Eigensystem, you can pose your equation orthogonal to the Eigenvector using a scalar Lagrange parameter (from NumberSpace).
Thank you very much for the reply. I have computed the eigenvalues/eigenfunctions in advance using Arnoldi solver; the matrices are symmetric and non-negative definite.
I am not sure yet how to use a scalar Lagrange parameter (from NumberSpace), is there a short illustrative example on this?
Ok I’m sorry I was wrong… With Joachims comment I think it’s actually quite easy…
I think this should do what you want:
mesh = Mesh(unit_square.GenerateMesh(maxh=0.3))
h1=H1(mesh,order=5,dirichlet="bottom|left|right|top",complex=True)
u,v = h1.TnT()
a = BilinearForm(h1)
a += SymbolicBFI(grad(u)*grad(v))
b = BilinearForm(h1)
b += SymbolicBFI(u*v)
b.Assemble()
evecs = GridFunction(h1,multidim=50)
vlam = ArnoldiSolver(a.mat,b.mat,h1.FreeDofs(),evecs.vecs,1)
Draw(evecs)
# get a non multidim GF out of the multidim one
evec0 = GridFunction(h1)
evec0.vec.data = evecs.vecs[0]
number = NumberSpace(mesh,complex=True)
fes = FESpace([h1,number])
(u,unum), (v,vnum) = fes.TnT()
# The orthogonality condition is satisfied because vnum = 1 means that evec0 * u = 0
# unum incorporates the evec0 part of the right hand side, if the argument of f is orthogonal to
# evec0, then unum should be 0
alam = BilinearForm(fes)
alam += SymbolicBFI(grad(u) * grad(v) - vlam[0] * u * v + unum * v * evec0)
alam += SymbolicBFI(evec0 * u * vnum)
f += SymbolicLFI(1*v)
alam.Assemble()
sol = GridFunction(fes,"solution")
sol.vec.data = alam.mat.Inverse(fes.FreeDofs()) * f.vec
Draw(sol.components[0])
