I have produced a mesh for a spheroid with the attached .geo file, both using the GUI and from the command line using -batchmode. However, upon saving this as a .vol file (also attached) the geometry information is not contained at the bottom of the .vol file,
csgsurfaces 2
undef 0
undef 0
this, in turn, leads to a problem after loading the mesh with the following commands
ngmesh = ngmeshing.Mesh(dim=3)
ngmesh.Load("Spheroid.vol")
mesh = Mesh("Spheroid.vol")
and then attempting to use the command
mesh.Curve(5)
Is there something I’m doing wrong here?
Attachment: Spheroid.geo
Attachment: Spheroid.vol
Hi Ben,
No, you are not doing something wrong. The Ellipsoid class in Netgen doesn’t implement the functions Get/SetPrimitiveData(), which are needed to save the geometry in a mesh file.
I will let you know when this is fixed.
Hi Matthias,
Thank you very much, that’s excellent.
Kind regards,
Ben
Hi Matthias,
Thank you for doing that, I am struggling to use the nightly release, has it been included in this? Do you know when the next stable release with this included will be?
Thanks again for your help,
Ben
Hi Ben,
Yes, It’s included in the nightly, which I advise to use in your case (we are running the same test suite for nightly builds and stable releases).
I don’t know when the next version is going to be released.
Hi Matthias,
Ok, thank you for you help.
Kind regards,
Ben
Hi Matthias,
I’m still getting an issue while using a version later than
NGSolve-6.2.1910.dmg 2019-12-19 03:44 53M
When running the later versions I get the following error when trying to importing NGSolve.
File "main.py", line 90, in <module>
from Settings import DefaultSettings
File "Settings/Settings.py", line 4, in <module>
ModuleNotFoundError: No module named ‘ngsolve'
I am running Python 3.7.1 on Mac OS 10.13.6.
Kind regards,
Ben
Oh, forgot to mention that we switched to Python3.8 for MacOS installers. It’s possible to have multiple python versions installed, you just need to check and possibly adapt your environment variables.
which python3
/Library/Frameworks/Python.framework/Versions/3.8/bin/python3
