after compiling ngsolve with cuda-support, I tried to run the
basic examples from ngscuda/examples/unifiedvector.py.
The results are not as expected (see the listing below).
Does anyone have any idea what could be causing this?
I have not found any clues in the documentation.
Thank you,
I compiled the new version (‘6.2.2307-7-gacaa2a3a3’) but still
have some problems to interpret the results (see the file below).
Why do I get an all zero result vector in the final print statement?
May be I misunderstood how to handle UnifiedVectors.
Could you please give me a hint?
Thanks,
I am still wondering how to use UnifiedVectors. In the example below
I start with a numpy array and use it to generate a corresponding
UnifiedVector. This correctly allocates memory on the GPU.
Then I define u2 = u + u followed by u2e = u2.Evaluate(), which
also allocates some memory on the GPU.
The next step is u2e.UpdateHost() to copy the result from GPU
to CPU. But when I print u2e, all components are 0.
I’ve got the impression, that calling UpdateHost() has no effect
at all.
It would be nice to get some help on this issue.
