- Surface gradient of a scalar H1 finite function u:
math syntax: (I - nn^T)Grad(u)
fes = Compress(H1(mesh, order=2, definedon=mesh.Boundaries("top")))
u = GridFunction(fes)
Grad(u).Trace() # Surface gradient of scalar H1 finite element function.
- How about the surface gradient of a vector-valued H1 finite element function U?
math syntax: (I - nn^T)Grad(U)(I - nn^T)
(refer to (2.2) in the link paper)
However, Do the following codes work?
fesvec = Compress(VectorValued(H1(mesh, order=2, definedon=mesh.Boundaries("top") , 2) ) # same as VectorH1
U = GridFunction(fesvec)
Grad(U).Trace() # I don't believe this is correct for surface gradient of a **vector-valued** H1 finite element function **U**
Does the Trace() Operator work well also for vector valued function? If not, what should I do to code the the surface gradient of a vector-valued H1 finite element function U correctly?
Coulson
