The (projective) Lehrenfeld-Schölberl stabilization function
I’m trying to implement an HDG method with reduced stabilization for second-order diffusion problems. Precisely, I want to use the (projective) Lehrenfeld-Schöberl stabilization function.
Is this function already available in NGSolve, or should I create it?
Regards,
Gregory
Hi Gregory,
It’s available in NGSolve. Attached is a minimal example. You may also want to have a look at the documentation of FacetFESpace. To do so type
help(FacetFESpace). The key is the two flag
highest_order_dc
and
hide_highest_order_dc
which do the projected-jumps trick as explained in 2.2.2. in this (preprint version of the ) paper: https://arxiv.org/pdf/1508.04245.pdf . For the even more basic stuff about HDG in NGSolve I refer you to the i-tutorial 2.8, see
https://ngsolve.org/media/kunena/attachments/743/hdg.pyhttps://ngsolve.org/docu/latest/i-tutorials/unit-2.8-DG/DG.html .
Attachment: hdg.py
Hi Christoph,
Thank you for your response.
I follow the same steps for the FESpace as in the attached script. In the function, I have set “highest_order_dc = true” and “hide_highest_order_dc = True”.
Now it works fine.
Thanks,
Gregory
