Trying to run usermeeting 2019 example of moving meshes
using code provided and converted to jupyterlite, changed Draw and inverse solver from umfpack to sparsecholesky, runs but the Newton evolution is unstable, any ideas?
t = 0.004
Newton iteration 0
err = 0.47488232780718304
Newton iteration 1
err = 46.878802931960614
Newton iteration 2
err = 598089124.7894585
Newton iteration 3
err = 1.9174661607616916e+30
Newton iteration 4
err = 9.700328834485895e+94
Newton iteration 5
err = nan
Newton iteration 6
err = nan
Newton iteration 7
err = nan
Newton iteration 8
err = nan
Newton iteration 9
err = nan
Newton iteration 10
err = nan
Newton iteration 11
err = nan
Newton iteration 12
err = nan
Newton iteration 13
this simpler example shows the same issue; everything works up to the NS Newton part
since its restricted to NS, and even though it works as-is in non-jupyterlite, i have reduced the time step and increased nu, no effect.
ah - think the problem here is that sparsecholesky is not meaningful for non-symmetric problems, and may also not work for non-positive definite matrices.
thanks, i will look again at getting umfpack.
any others work?
although i have been using sparsecholesky with the NS examples.
I think the only available direct solver in jupyterlite that can solve nonsymmetric/ not pos definite is “superlu”
