I’ve been trying to work on my GPU for solving the Helmholtz equation. I followed the guide from 5.5.1 in the documentation, where to use cuda/gpu you’re using
try:
from ngsolve.ngscuda import *
except:
print (“no CUDA library or device available, using replacement types on host”)
This check throws the exception. I have CUDA 11.8 installed in my machine, and the nvcc --version command has the following output
nvcc: NVIDIA (R) Cuda compiler driver
Copyright (c) 2005-2022 NVIDIA Corporation
Built on Wed_Sep_21_10:41:10_Pacific_Daylight_Time_2022
Cuda compilation tools, release 11.8, V11.8.89
Build cuda_11.8.r11.8/compiler.31833905_0
I’ve installed Ngsolve in Windows 11, using pip install --pre ngsolve.
Do I need to build the code from scratch in order to have GPU support? I can’t find something in the documentation regarding this issue.
