Hello. I try to find shielding effectiveness of shielding enclosure using ngsolve.
For finite element analysis in the frequency domain, the governing wave equation can be written as: curl(1/mucurl(E)) + kkE=f.
I created FES as: fes = HCurl(mesh, order=4, nograds = True, complex=True),
defined materials and constants,
defined bilinear form: a = BilinearForm(fes)
a += SymbolicBFI(1/mucurl(u)curl(v) + kkuv).
But I don’t now how to define boundary conditions and how to set the incident electric field as a plane wave.
Can anyone give me some example how to solve Maxwell’s equations in time-harmonic form in NGSolve?
I try to find the total electric field in region of space. The region consists of two domains: air and metal plate. For material of plate I choose the PEC (perfect electric conductor with electrical conductivity equal to 1e30). And I don’t need to culculate the field inside the plate.
There are no current sources in region. The excitation is a plane wave.
I add the complex-valued Robin boundary condition to my scrypt file, but i can’t get the right result.
I try to implement something like that in the paper.
Yes, you are right. The incoming wave is not that I expect. I correct this. But the problem still exists.
I understand, that I do not have enough knowledge about ngsolve. That’s why I deside to use more simple 2D example.
There is file scattering.py in py_tutorials folder. I tried to modify it for maxwell equations. But despite the fact that this is a simple example I did not succeed.
Now I can’t find there is the problem. Two files are in attachments.
I found mistake in coefficient. Now it works.
But I am not sure about PML. Is it necessary to use it in my problem? The results are diferent whith it and without.
