I am trying to make a vector version of MyCoefficientFunction.
I am refeering to mylittelengsolve.
I find
// ********************* Necessary **********************************
virtual double Evaluate(const BaseMappedIntegrationPoint& mip) const override
// maybe do something with mip and trafo?
auto pnt = mip.GetPoint();
return pnt[0] * pnt[1];
// ******************* Performance improvements **********************
in “myCoefficient.hpp”. This I suppose is a function, but how come it is written in .hcp file? Isn’t it a header file? How do I make it a vector function? I searched in the source files, but I could not find a similar file that I could refer to.
here are some examples (unfortunately not on the tutorial level as MyLittleNGSolve):
The specialcf.normal(3) ends up as a cl_NormalVectorCF class:
The inverse of a matrix-valued CF leads to an InverseCoefficientFunction:
The CF can be tensor-valued (scalar, vector, matrix, or higher order tensor). This is specified by SetDimensions. The Evaluate function writes values linear into a vector (last index is inner dimension)
A difference is whether a CF is a node of the expression tree (like NormalVector), or if it depends on one or serveral input CFs (like InverseCF). Then automatic differentiation for the node shall also be provided.
