Hi there,
I want to define a CF with different values inside the mesh (solids) and on the boundaries (faces). I expect that if I only assign values to the solids, the values on the faces remain unchanged (zero by default), but in the example below, the values on two faces are also changed. Please see the attached screenshot. As you see in the image, the top and right faces of the ‘part1’ material have different values than zero. Would be highly appreciated if anyone could help with this, please.
from netgen.csg import *
from ngsolve.solvers import *
#import matplotlib.pyplot as plt
box1 = Box((0,0,0), (2.2,2,1))
box2 = Box((0,0,0), (2.2,-1,1))
box3 = Box((0,0,1), (2.2,-1.01,3))
box4 = Box((0,-1,-2), (3,-3,7))
box1.solids.name = 'part1'
box2.solids.name = 'part2'
box3.solids.name = 'part3'
box4.solids.name = 'subsoil'
geo_conc = Glue([box1,box2,box3])
geo_conc_soil = Compound([geo_conc, box4])
geo = OCCGeometry(geo_conc_soil)
mesh = Mesh(geo.GenerateMesh(maxh = 0.5))
cfVals= {'part1':0, 'part2':30, 'part3':40, 'subsoil':50}
cf = CoefficientFunction([tttl[mat] for mat in mesh.GetMaterials()])
Draw(cf,mesh)
Regards
HA
