Hi Everyone,
I am trying to solve the Maxwell eigenvalue problem in a 2.5D domain following the example in the documentation. Below is a mwe:
r = y
m = 0
def a1(arg1, arg2):
return r * curl(arg1)*curl(arg2)*dx
def a3(arg1, arg2):
return m*(arg1[0]*grad(arg2)[0] + 1/r*arg1[0]*arg2[0])*dx
def a4(arg1, arg2):
return m**2/r*(r**2*grad(arg1)[0]*grad(arg2)[0] + r*grad(arg1)[0]*arg2 + r*arg1*grad(arg2)[0] + arg1*arg2)*dx
def b1(arg1, arg2):
return r*arg1*arg2*dx
def b2(arg1, arg2):
order = 2
VrVz = HCurl(mesh, order=order, dirichlet=".*")
um, vm = VrVz.TnT()
G, Vphi = VrVz.CreateGradient()
V = VrVz * Vphi
(u, u_phi) = V.TrialFunction()
(v, v_phi) = V.TestFunction()
a = BilinearForm(a1(u, v) + a4(u_phi, v_phi) + a3(u, v_phi) + a3(v, u_phi))
b = BilinearForm(b1(u, v) + b2(u_phi, v_phi))
mmat = BilinearForm(b1(um, vm))
apre = BilinearForm(a1(u, v) + a4(u_phi, v_phi) + a3(u, v_phi) + a3(v, u_phi) + b1(u, v) + b2(u_phi, v_phi))
pre = Preconditioner(apre, type="direct", inverse="sparsecholesky")
b.Assemble()
mmat.Assemble()
apre.Assemble()
I_phi = IdentityMatrix(Vphi.ndof, complex=True)
GT = G.CreateTranspose()
math1 = GT @ mmat.mat @ G
math1[0, 0] += 1
invh1 = math1.Inverse(inverse="sparsecholesky", freedofs=Vphi.FreeDofs())
proj = IdentityMatrix(V.ndof, complex=True) - BlockMatrix([[G @ invh1 @ GT @ mmat.mat, None],
[None, I_phi]])
projpre = proj @ pre.mat
evals, evecs = solvers.PINVIT(a.mat, b.mat, pre=projpre, num=4, maxit=20, printrates=True)
When I try to run this, I get the error
---> 51 evals, evecs = solvers.PINVIT(a.mat, b.mat, pre=projpre, num=4, maxit=30, printrates=True)
File ~\AppData\Roaming\Python\Python311\site-packages\ngsolve\eigenvalues.py:87, in PINVIT(mata, matm, pre, num, maxit, printrates, GramSchmidt)
85 for v in vecs[0:num]:
86 v.SetRandom()
---> 87 uvecs[:] = pre * vecs[0:num]
88 lams = Vector(num * [1])
90 for i in range(maxit):
RuntimeError: Bad dynamic_cast!
which I think has something to do with the way that I am building the preconditioner BlockMatrix. How can I fix it?
Best regards
