Writing the meshes as BREP file or MSH file using python api
I’m trying to create a simple geometry of a fusion of two spheres using the python api of netgen.
Going through the tutorials I have written the following code,
from netgen.csg import *
sphere1 = Sphere( Pnt(0,0,0), 12.0 )
sphere2 = Sphere( Pnt(20,0,0), 12.0 )
geo = CSGeometry()
geo.Add( sphere1 + sphere2 )
mesh = geo.GenerateMesh(maxh = 1.0)
mesh.Save("twospheres.vol")
This code is working, however I would like to save this in a ‘brep’ file or ‘msh3’ file ( gmsh file format).
Is there any way to do this ?
also, this “vol” file format can not be opened by Netgen. Is there any way to open and visualize the saved ‘vol’ file later ?
Thanks for your help.
Hello renard,
checkout this forum thread about exporting the mesh to other file formats. Essentially you need to do
mesh.Export(filename, format)
I had no issue opening the mesh in the netgen gui via File > Load Mesh. One alternative to visualise the mesh via ngsolve would be to export a vtk with the constant 1 as the CoefficientFunction and then to visualise this in Paraview.
Best wishes
Henry
Hi renard,
to load the Netgen mesh from python, you have to do the following
from netgen import meshing
m = meshing.Mesh(3) # create a 3-dimensional mesh
m.Load("twospheres.vol")
To export the mesh, use the function suggested by Henry.
Hi, Thank you. I could export the mesh in Gmsh2 file format. However, I could not find the option to save the geometry as a boundary-representation (brep) file. Can you help me with that too?
I am not sure if BREP is supported. If you go to File → Export Filetype, you can see the list of supported filetypes.
