Hi everybody!
I have tried to mesh a sheet.
First I mesh it in meters, than in decimeters, than in centimeters and finally in millimeters.
It is quite simple in my opinion, however it does not work properly.
Meter, dm, cm work fine but mm fails.
What do I do wrong?
Cheers, Valentin
from netgen.csg import *
def foo(scale = 1):
thickness = 0.18
origin = Pnt(0, 0, 0)
corner = Pnt(9*scale, 4*scale, thickness*scale)
left = Plane (origin, Vec(-1,0,0) )
right = Plane (corner, Vec( 1,0,0) )
front = Plane (origin, Vec(0,-1,0) )
back = Plane (corner, Vec(0, 1,0) )
bot = Plane (origin, Vec(0,0,-1) )
top = Plane (corner, Vec(0,0, 1) )
cube = left * right * front * back * bot * top
geo = CSGeometry()
geo.Add (cube)
mesh = geo.GenerateMesh(maxh=1)
mesh.Save("cube.vol")
if __name__ == "__main__":
ngsglobals.msg_level = 0
print("it works with scale 1:")
foo(1)
print("it works with scale 0.1:")
foo(0.1)
print("it works with scale 0.01:")
foo(0.01)
print("it does not work with scale 0.001:")
foo(0.001)
# from ngsolve import *
# mesh = Mesh("cube.vol")
# import netgen.gui
# Draw(mesh)
print("done")
# input()
