I am trying to mesh a geometry that consists of a cube with a sphere and cylinders cut out. I want to use the physical sizes of the domain, which means there are some small features I want to resolve. The attached script works fine if the geometry is, for example, in a unit cube, but crashes or gets stuck if letting the size of the domain be smaller than 1/1000. (1/1000 works, but 1/1100 fails. The size I want to use is 1/2800).
All features that I want to include are scaled with the side length of the cube, hence it is only a matter of scaling the size of the gridded domain.
I have tried several things, which makes it fail in different ways.
- If I do not specify a maxh, the script hangs and gives a segementation fault when I stop it.
NETGEN-6.2.2403
togl-version : 2
OCC module loaded
loading ngsolve library
NGSolve-6.2.2403
Using Lapack
Running parallel using 16 thread(s)
Start Findpoints
Analyze spec points
Find edges
Start Findpoints
Analyze spec points
Find edges
Start Findpoints
Analyze spec points
Find edges
Surface 1 / 16
Thank you for using NGSolve
Segmentation fault (core dumped)
- If specifying maxh (relative to the cube side length) it gives an error and then hangs.
NETGEN-6.2.2403
togl-version : 2
OCC module loaded
NGSolve-6.2.2403
Using Lapack
Start Findpoints
Analyze spec points
Find edges
Start Findpoints
Analyze spec points
Find edges
Start Findpoints
Analyze spec points
Find edges
Surface 1 / 16
ERROR: Problem in Surface mesh generation
File "<string>", line 38, in <module>
netgen.libngpy._meshing.NgException: Problem in Surface mesh generation
Do I have to respect anything in terms of mesh size? Or are there any constraints or limitations for gridding small features in netgen?
I found a similar post in the old forum, but it did not explain the solution nor solve my problem.
smallmesh.py (1.1 KB)
